BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,294 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: May 2009 Posts: 3 New Guy | New Guy Joined: May 2009 Posts: 3 | Hi can the 19.5 rv wheels be used --with possibly opening up the center hub holes? do they share the same 5 bolt pattern? | | | | Joined: Jul 2005 Posts: 581 Shop Shark | Shop Shark Joined: Jul 2005 Posts: 581 | I've heard of people using them. Check these posts out... 19.5" Wheels and Check Grigg's comment | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | You might be able to use them.... if they fit over your drums. Only way to know for sure is try. Bolt circle will be the same 10 lug on 7.25". Center hole on the19.5" wheels will be 5.25" so you'll need some bushings to adapt your 4.75" hubs.
Grigg | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | 'Bolter Joined: Mar 2004 Posts: 3,068 | Wouldn't fit my 48 4400.... Scott | | |
