4 members (Southerntruck, Phak1, DaveV, 2-Ton), 90 guests, and 2 robots.
Topics128,035
Posts1,055,566
#765551 07/25/2011 11:53 PM
can i use small block moter mounts to put a 4.3 in a 1950 1/2 ton
#765659 07/26/2011 5:55 AM
Depends on which 4.3L engine you are referring to. Most likely TooMany2count's answer is what you need, but some 4.3s would be quite easy to install.
