3 members (JW51, Otto Skorzeny, Gdads51), 128 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#765477 07/25/2011 8:30 PM
1st time ever my 63 left me stranded today. Not getting any fuel. I had a can of starting fluid and sprayed in in the carb, it runs until the ether is gone then stalls. I have yet to pour gas in carb, gonna wait until dusk cause it's too blamed hot! I'm thinking fuel pump or filter. It is full of gas, I use lead additive. It was over 100 degrees and I didn't feel like having another heart attack today, so I called a tow ($70.00). Truck is an in-line 6. How much of a P.I.T.A. is it to remove and replace fuel pump? Could anyone please provide step by step or trouble shooting instructions?
Pete
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
given the high temperatures, it could have just been a vapor lock. see what it wants to do when it is cool in the morning.
edit: and of course check the obvious, is there any gas in the tank?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
There are two bolts on the fuel pump, takes 10-15 min to swap. One fuel line in and one out. Fairly simple. The fuel pump is on the passenger side towards the front.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
jon1963 #765503 07/25/2011 9:16 PM
If it comes down to changing the fuel pump, borrow or buy the appropriate line wrenches so you don't round off the fittings with your crescent wrench or pliers.
1953 Chevrolet 3600
Full tank of gas, roger that on the fuel line wrenches. I will try to re-start in the AM prior to beginning surgery. Thanks Guys!
you can also disconnect the gas line from carb,
have someone turn the engine over , watch and
see if any gas is being pumped out of the line..
if not you need a fuel pump..
Redryder pix
My Hotrod
joker #765657 07/26/2011 5:50 AM
Riding in the Passing Lane
Look for a fuel filter underneath. Often a previous owner has put a filter between the tank & pump on these old trucks. I know I do.
1972 Chevy c10 Cheyenne Super
I had a situation like this and the strainer on the end of the pick-up tube on the sending unit in the tank was clogging from the sediment in the tank. When the sediment was agitated and the pump was pulling, it would starve the line of fuel, causing the truck to die. We removed the sock from the end of the sender pick-up tube and installed a good filter in the line between the pump & carb and never had the problem again. After running a few tanks of fuel through it and changing the filter a few times, the sediment was no longer floating around in the tank and the problem went away.
The fuel pump test mentioned above will isolate the problem to the fuel pump, if that is the issue. Good luck.
