| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | 1st time ever my 63 left me stranded today. Not getting any fuel. I had a can of starting fluid and sprayed in in the carb, it runs until the ether is gone then stalls. I have yet to pour gas in carb, gonna wait until dusk cause it's too blamed hot! I'm thinking fuel pump or filter. It is full of gas, I use lead additive. It was over 100 degrees and I didn't feel like having another heart attack today, so I called a tow ($70.00). Truck is an in-line 6. How much of a P.I.T.A. is it to remove and replace fuel pump? Could anyone please provide step by step or trouble shooting instructions? Pete 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | given the high temperatures, it could have just been a vapor lock. see what it wants to do when it is cool in the morning.
edit: and of course check the obvious, is there any gas in the tank?
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | There are two bolts on the fuel pump, takes 10-15 min to swap. One fuel line in and one out. Fairly simple. The fuel pump is on the passenger side towards the front. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | If it comes down to changing the fuel pump, borrow or buy the appropriate line wrenches so you don't round off the fittings with your crescent wrench or pliers. | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | Full tank of gas, roger that on the fuel line wrenches. I will try to re-start in the AM prior to beginning surgery. Thanks Guys! 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you can also disconnect the gas line from carb, have someone turn the engine over , watch and see if any gas is being pumped out of the line..
if not you need a fuel pump.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Look for a fuel filter underneath. Often a previous owner has put a filter between the tank & pump on these old trucks. I know I do. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I had a situation like this and the strainer on the end of the pick-up tube on the sending unit in the tank was clogging from the sediment in the tank. When the sediment was agitated and the pump was pulling, it would starve the line of fuel, causing the truck to die. We removed the sock from the end of the sender pick-up tube and installed a good filter in the line between the pump & carb and never had the problem again. After running a few tanks of fuel through it and changing the filter a few times, the sediment was no longer floating around in the tank and the problem went away.
The fuel pump test mentioned above will isolate the problem to the fuel pump, if that is the issue. Good luck. | | |
