2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#765351 07/25/2011 5:26 AM
1 Offline
you know the screw that holds the windshield to the regulator? anyway, i used pb blaster, then an impact driver, (wouldn't fit), then i cut it off with a dremmel thinking if i could get it into the vice i could use easy outs. then i broke the easy out. then, i broke the drill bit trying to drill out the easy out. now it has an easy out tip stuck in it, and a piece of drill bit. there are no ends to grab. i'm gonna take it to a machine shop. at this point the threads are intact, but nothing else. and, there is not enough room to put a weld on it. not to mention that with my skill, i would weld everything but the screw. and, the piece is riveted on and i don't see anyone selling this part!
any ideas frown
http://s1233.photobucket.com/albums/ff393/fletch41/
1941 Chevy 1.5 Ton, (soon to be flatbed), dubbed the "USS Coral Sea" which I served on while in the military. wink ~m
wink
~fletch
well, sounds like your plan of taking it to a shop might work - at least you understand now why shops charge so much for restoration work wink in the past some of the vendors sold rebuilt regulators, or would rebuild yours - Jim Carter comes to mind as a possibility
Yeah, convert to a fixed front windshield like mine. Sounds like even I have better luck than you. Tough day. Nothing an adult beverage or two cant fix though.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
1 Offline
i spent a bunch of money to insure this windshield works. i had a 46 about 30 years ago, it's a big part of the allure. i WILL make this work. and, i don't care what i have to sell to finance this project! wink
wink
~fletch
I don't have anything to add that might help you but I sure admire your spirit! No surrender! Good for you!
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
There is a guy who advertises on our local craigs list that has an electronic process for removal of broken bits/easy-outs without damage to threads.
Looks like you're nearby.
Found it....
Grafton Metal Disintegration
714-623-3567
www.mobileextraction.com
Even makes house calls!
This is what is called an Easyout nightmare. That is why I hate those things. There have been postings on here where people heat the easyout up to cherry red, let it cool and it becomes soft.
1951 1 Ton Completed
Easyout, what a misnomer. I have never gotten anything out with an Easyout. You should use the "BIG CHEVY 3600 easyout, a 6 lb sledge and a 15" chisel.
~Jim
Now that you got it loosened up you should be able to take it out with your fingers. grin grin
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
