4 members (Gdads51, Hotrod Lincoln, Bill Hanlon, 1 invisible), 100 guests, and 2 robots.
Topics128,131
Posts1,056,369
Members48,441
The '34 engine has finally died. I am looking to replace it with a more reliable engine, probably a 235. My question is whether or not a 1955-1957 235 will mate up with my 1934 3 speed tranny.
1 Offline
I had a '35 and I put in a full pressure 216 I found from a vendor in Texas. I did use a new pilot bearing, flywheel, clutch and pressure plate. I even used the same accelerator linkage with a few modifications. The motor mounts are the same.
Normbc9
If you have a 34 master or truck you will need:
1938-46 truck bellhousing to mate to the 235 engine and 34 master/truck transmission.
You will also need a front bearing retainer from a 1938-46 truck 4 speed. It has a sleeve for the needed ball bearing throw-out bearing.
It is not so easy if you have a Standard.
My Blog
