| | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I'm talking to a guy who's selling a 235. The casting number on the block is 3836233 making it a '55-57 235 per inliners.org. However, he states there is also a plated attached to the block with screws which reads, CON4 G205. Does anyone know what this code is or what it might mean and why its attached via a screwed on plate? Also, without a doubt this is a full pressure engine right (since it's a '55 at oldest)? Thanks fellow Stovebolters! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It means it was cast on July 20, 1955. The plate was screwed onto the mold, not the block. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Thanks Cletis you rock. So, it would be full pressure right?
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "Also, without a doubt this is a full pressure engine right (since it's a '55 at oldest)?"
Now that is an obvious case of self-doubt..... Rest easy big Tee...your doing fine.
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Thanks 53.  | | |
