| | | Forums66 Topics128,167 Posts1,057,022 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | I finally got a LCF truck. Its a 57 5700 series. Not too bad of shape. Its just the body, frame cut behind the cab. I also bout a 2003 GMC W4500 HD cab over for the chassis and drive train. Now the fun starts. Making it a crew cab with a 59 fleetside bed with stepside fenders cut down and bolted on to make it a dually bed. I thought this was going to be a 2 yaer project but the wife actually wants it done by spring so she can get a new 5th wheel camper. I guess it could be worse, she could be yelling at me about spending money and working on it. Here are some pics [IMG]http://inlinethumb11.webshots.com/48778/2757394000102329435S600x600Q85.jpg[/IMG][IMG]http://inlinethumb61.webshots.com/46908/2850038230102329435S600x600Q85.jpg[/IMG]I had to take the wheels off and bolted casters to the bottom of the sprins so it would fint through the garage door.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I can't open the pictures. | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Buggy, I get a "forbidden" message when I click on the link. Looking forward to seeing them.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | works here - looks good - not sure how you'll work on it stuffed into that mini-garage tho  you guys might find it works if you highlight the link and copy it to paste in the address bar Bill | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | That worked, thanks Bill!
Cool truck. It does look a little tight but I'm sure wyou will make it work! Keep us up to date on your progress. | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Ok I fixed the pics. I am a little tech-tarded sometimes when it comes to posting pictures | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not your 'mistake' buggy, and you haven't actually changed anything, the problem is the link turns into something other than what it appears, a 'referrer click thru' of some kind, which some browsers protection setup will reject ..... hover the mouse on the link, right click and select copy, then paste it into an address bar and look at how it's grown  Bill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Looks good. I've owned two of them. A 1955 5700 series, & a 1956 5700 series. I've always wanted a Heavy Duty '56, or '57 model 7000, or 9000 series LCF. Always liked how you had to pull on both hood latch levers, at the same time, then push the hood up with your shoulder. | | |
