7 members (49nut, moparguy, ndkid275, Barry Martak, tclederman, kades51, 1 invisible), 78 guests, and 3 robots.
Topics128,133
Posts1,056,396
Members48,441
#763502 07/18/2011 2:11 PM
Does anyone make or know who makes an aluminum valve cover for a 261? I do not want one that has the bolts coming up though the top of the cover and I do not want one that has a name on the top either unless it says Chevrolet. I am I dreaming or can I find one?
What are you willing to pay? There are a number of machine shops needing work in these times we're going through so for probably around $200 or so for the size of aluminum billet you'd need and their standard shop time you can get ANY style of valve cover you desire. I got a set of Sullivan Chrysler style hemi covers for my dohc 4.6 Cobra for around $700 with shipping.
Evan
1 Offline
K9sicem,
Look around, there are several that are drilled around the perimeter for the 235-216 (Same dimensions) and also have no identifier. I suggest you look first at the www.inliners.org site and start from there. They have vendors who advertise with them for inline specific items.
Normbc9
It seems to me chevs of the 40's has them or can get them, (I've been waiting a while for mine, but then again I have been working on this project for about 4 years, I can wait a bit.)
Inliner Tom S. (6inarow) cast a batch of smooth top ones with the 216 type 2 hole mounting that have enough material on the top to engrave any desired pattern etc. A 4 bolt aluminum one would have to be a one off and the last time I checked the material alone was over $300.00. With a piece of aluminum that big you might as well just make a crossflow head with it. grin Spraying cast aluminum looking paint on a tin one is about the only way to keep 4 bolts.
You Tube
You could fabricate one from 1/8" aluminum and a thicker flange.
