| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Why did most older vehicles use a braided ground cable and why did we stop using them. I am trying to decide whether to use a braided ground on my 1952 or just a regular cable. The braided cables don't have a gauge rating like copper cables. How do you know if it is adequate or not?
Chuck | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the pre-made ones are 2 gauge and are tin coated copper, nothing better, ordinary standard cables are just cheaper, which is why braided aren't used OEM much now, grounds aren't quite as important on 12V - you'll still find flat braided grounds on a lot of high end tech equipment - go with the best  Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | NAPA had one size of braided ground cable the last time I asked. It was 6 gauge and inadequate for a 6v system. Jim Carter indicates he has "correct" braided cable and that could mean 2 gauge or fatter. If it is 2 gauge, it would be OK, but a thicker cable would be better. I use round/covered 2/0 (00) gauge ground cable and get it long enough to run from the battery to a starter bolt. http://www.waltstractors.com/acatalog/Ground_Cable-Flat_Braided.html | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I use a flat braided ground cable (about 2 1/4 inches wide) to go from engine to frame. I use a "zero" gauge cable to go from Battery to engine.
I use a round braided cable from body to frame "mid ship" just to be sure.
Proper grounding is the key to a good wiring job!
Mike
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | My original braided cable looked pretty funky. I had a container of used phosphoric acid that I thought was used up. I threw the cable in that and forgot it for about a week. Most of the tin is gone and it is clean copper wire. I suppose this will oxidize or sulfate up if I try to use it in that condition or will it?
The only braided cables I have seen do not indicate a gauge rating. Finding 2/0 cable anywhere around here hasn't happened for me. The last time I tried at a starter/alternator rebuilder place I left after the owner insisted that 1 gauge was a bigger cable than 2/0. Drawing 2 zeros on his notepaper helped about as much as if I drew them on his forehead.
Chuck | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Chuck - yes the bare copper will oxidize and wind up weakening - being nice and clean, you could get a good 200W soldering iron or gun and some 60/40 straight wire solder and paste flux and re-tin it yourself, just don't flow so much solder on it gets stiff - good as new
Bill | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Tractor Supply has several sizes of braided ground strap, at least when I got one a few years ago. I used to work at Carquest, and we could get a wide range of sizes....NAPA should be able to, also.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The braided cable (and non-braided cable) will not oxidize much (if any) if you coat the contact surfaces with non-oxidizing conductive grease (available off the shelf from NAPA).
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | In Tech Tips there is some useful info in the Electrical Systems category too.
Drew
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Thanks for all the help and suggestions. Drew, I just read thru most of the Tech Tips again. It just proves I don't understand everything I know about electricity.
Chuck | | |
