6 members (Peggy M, cmayna, baldeagle, JW51, fonz8261, obs2kl), 56 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#762838 07/15/2011 8:38 PM
i installed one to day and now the vehicle won't start any suggestion of what test i can perform.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #762852 07/15/2011 8:48 PM
Riding in the Passing Lane
First take out the coil wire from the dist, crank the engine with the wire about 1/4 in from metal. It should shoot a strong spark. If not get out the directions & make sure every thing is hooked up correctly. Get a test light & see if you have power comeing from the ign. switch. Petronix probably has a hot line to help you.
1972 Chevy c10 Cheyenne Super
Did the test and no spark. i called the tech line at the co. i bought it from and they sent me a trouble shooting sheet and i seem to have done it right. no juice coming from the coil. new compatible coil so i am stumped. new wires, and cap.
2017 Buick Encore
See more pix
WE b OLD #762918 07/16/2011 12:38 AM
What is the part number of the PertronIx unit?
What is the year of your engine and the voltage and ground polarity of your electrical system?
tclederman #762919 07/16/2011 12:47 AM
Tim,I know he has a 235 and a 12 volt system,don't know the year.
1951 3100 Chevrolet
bowtietim #762929 07/16/2011 1:53 AM
Where is your rotor pointing with the needle on ball?
I had a problem when I reinstalled my distributor the rotor was off.
Had to move oil pump with screw driver for the tang to line up properly.
re-time from square 1
DADS50 #762957 07/16/2011 3:18 AM
He's working on an MGA, guys. All bets are off.
Cletis #762980 07/16/2011 5:02 AM
Oops. Is it a twin cam MGA?
tclederman #763013 07/16/2011 12:30 PM
it is not a twincam. i have had this car since 1968 and it has never failed me. now that i have installed the pertronix system i can't get it started. have talked to Moss Motors where i bought it they can't figure it out either. Shame on you Cletis i was trying to keep a secret so you would not delete it. blush
2017 Buick Encore
See more pix
WE b OLD #763025 07/16/2011 2:50 PM
Cletis will probably just move it to where it needs to be.
I don't know anything about MGA cars.
Tim
1951 3100 Chevrolet
bowtietim #763073 07/16/2011 8:28 PM
Cletis has nothing to do with moderating this forum.
There is a difference between diagnosing electrical problems on an American truck and a British car.
Cletis #763089 07/16/2011 9:39 PM
Lucas electrical systems- - - - -that's why the Brits drink warm beer - - - -they've got Lucas refrigerators!
Check out the connection where the point spring attaches to the distributor breaker plate. As I remember it, it's very easy to get a ground there which acts like the points are closed all the time. My MGA had a similar problem. It's been about 30 years since I've worked on that system, so my memory is a little fuzzy as to exactly how the insulators assemble. If the wiring harness is grounded there, the trigger signal never gets to the Pertronix amplifier. If it's been that way for very long, you might have fried the amplifier. Yes, I know the Pertronix eliminates the points, but the connection could still be wrong.
Hotrod Lincoln #763206 07/17/2011 1:13 PM
New installation i have emailing the mgaguru and he doesn't have an answer. i am sure it is some thing i did or did not do. i am going to order new points and try that then put them back just in case. the dist. did not have ground for who knows how long and i rigged one up. i have had this car for 43 years and it always started and ran great until this year. i let it set all last summer because i was dealing with the truck and it was so hot all summer. i should have well enough alone but i wanted to up grade the electrical. will talk to pertronics Monday.
2017 Buick Encore
See more pix
Hotrod Lincoln #763233 07/17/2011 4:01 PM
Hey, just a minute.... it was apparently running fine till the man installed an aftermarket AMERICAN ignition sysyem! wink
We drink warm beer cos we like the flavour of the stuff BTW; difficult when your taste buds 've just been nuked by iced swamp water! grin
My experience of MG's is very limited, but I wouldn't be surprised if the distributor plate is grounding as suggested above.
63 GMC Fleetside; overbuilt, over-thirsty and over here!
bowtietim #763235 07/17/2011 4:12 PM
pretty simple IMO-put the points back in....
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
64fleetside #763275 07/17/2011 7:33 PM
I think i will order a new set of points and a new rotor. and reinstall them and if that does it i will send the Pertronix back.
2017 Buick Encore
See more pix
WE b OLD #763282 07/17/2011 8:24 PM
why did you mess with it to began with...lol
Redryder pix
My Hotrod
Kev UK #763292 07/17/2011 9:00 PM
I made a bunch of pocket change in college, working on Jag, MG, Triumph, Austin-Healey, and other Lucas ignition and charging systems. They were just temperamental enough that the local mechanics in the backwoods Tennessee college town where I went to engineering school would run the other way when one drove (or more likely, got pushed) in! Spit on the sidewalk three blocks away, and a Jag XKE ignition system would drown out!
Hotrod Lincoln #763309 07/17/2011 10:23 PM
The same reason my truck is in the condition it is in, i wanted to improve its drive ability and i thought that was the way to go. AND, AND, AND i i have found out what the problem is. the ignitor has a big chunk out of the back side. how it happened i don't know but it is there. as per another post i though i would take a a quick look and well while i am here take the old one off and see about tightening down the mounting plate and that is when i saw it. this the first time it has let me down in the 43 years i have owned it. well i will see if pertronix will send a new one.
2017 Buick Encore
See more pix
WE b OLD #763385 07/18/2011 1:52 AM
Well back to your issue you were having. Did you remove the Ignition Resistor from the firewall. I know I installed it on my 235 and it fired right up. Has not had a issue with it in years. I know many people who have had them for 10 years and still no issues. Any how if you have not removed the Ignition Resistor that may be the issue.
Good luck
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
GrandpasTruck #763484 07/18/2011 9:52 AM
No resister but a cracked igniter.
2017 Buick Encore
See more pix
