0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i installed one to day and now the vehicle won't start any suggestion of what test i can perform.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | First take out the coil wire from the dist, crank the engine with the wire about 1/4 in from metal. It should shoot a strong spark. If not get out the directions & make sure every thing is hooked up correctly. Get a test light & see if you have power comeing from the ign. switch. Petronix probably has a hot line to help you.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Did the test and no spark. i called the tech line at the co. i bought it from and they sent me a trouble shooting sheet and i seem to have done it right. no juice coming from the coil. new compatible coil so i am stumped. new wires, and cap.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the part number of the PertronIx unit?
What is the year of your engine and the voltage and ground polarity of your electrical system?
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Tim,I know he has a 235 and a 12 volt system,don't know the year. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Where is your rotor pointing with the needle on ball?
I had a problem when I reinstalled my distributor the rotor was off.
Had to move oil pump with screw driver for the tang to line up properly.
re-time from square 1
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | He's working on an MGA, guys. All bets are off. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | He's working on an MGA, guys. All bets are off. Oops. Is it a twin cam MGA? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | it is not a twincam. i have had this car since 1968 and it has never failed me. now that i have installed the pertronix system i can't get it started. have talked to Moss Motors where i bought it they can't figure it out either. Shame on you Cletis i was trying to keep a secret so you would not delete it.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Cletis will probably just move it to where it needs to be.
I don't know anything about MGA cars.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Cletis has nothing to do with moderating this forum.
There is a difference between diagnosing electrical problems on an American truck and a British car. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Lucas electrical systems- - - - -that's why the Brits drink warm beer - - - -they've got Lucas refrigerators!
Check out the connection where the point spring attaches to the distributor breaker plate. As I remember it, it's very easy to get a ground there which acts like the points are closed all the time. My MGA had a similar problem. It's been about 30 years since I've worked on that system, so my memory is a little fuzzy as to exactly how the insulators assemble. If the wiring harness is grounded there, the trigger signal never gets to the Pertronix amplifier. If it's been that way for very long, you might have fried the amplifier. Yes, I know the Pertronix eliminates the points, but the connection could still be wrong. Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | New installation i have emailing the mgaguru and he doesn't have an answer. i am sure it is some thing i did or did not do. i am going to order new points and try that then put them back just in case. the dist. did not have ground for who knows how long and i rigged one up. i have had this car for 43 years and it always started and ran great until this year. i let it set all last summer because i was dealing with the truck and it was so hot all summer. i should have well enough alone but i wanted to up grade the electrical. will talk to pertronics Monday.
| | | | | Joined: Apr 2005 Posts: 46 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 46 | Lucas electrical systems- - - - -that's why the Brits drink warm beer - - - -they've got Lucas refrigerators! Hey, just a minute.... it was apparently running fine till the man installed an aftermarket AMERICAN ignition sysyem!  We drink warm beer cos we like the flavour of the stuff BTW; difficult when your taste buds 've just been nuked by iced swamp water! My experience of MG's is very limited, but I wouldn't be surprised if the distributor plate is grounding as suggested above.
63 GMC Fleetside; overbuilt, over-thirsty and over here!
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | have had this car since 1968 and it has never failed me. now that i have installed the pertronix system i can't get it started.
pretty simple IMO-put the points back in.... | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I think i will order a new set of points and a new rotor. and reinstall them and if that does it i will send the Pertronix back.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | why did you mess with it to began with...lol Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I made a bunch of pocket change in college, working on Jag, MG, Triumph, Austin-Healey, and other Lucas ignition and charging systems. They were just temperamental enough that the local mechanics in the backwoods Tennessee college town where I went to engineering school would run the other way when one drove (or more likely, got pushed) in! Spit on the sidewalk three blocks away, and a Jag XKE ignition system would drown out! Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The same reason my truck is in the condition it is in, i wanted to improve its drive ability and i thought that was the way to go. AND, AND, AND i i have found out what the problem is. the ignitor has a big chunk out of the back side. how it happened i don't know but it is there. as per another post i though i would take a a quick look and well while i am here take the old one off and see about tightening down the mounting plate and that is when i saw it. this the first time it has let me down in the 43 years i have owned it. well i will see if pertronix will send a new one.
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Well back to your issue you were having. Did you remove the Ignition Resistor from the firewall. I know I installed it on my 235 and it fired right up. Has not had a issue with it in years. I know many people who have had them for 10 years and still no issues. Any how if you have not removed the Ignition Resistor that may be the issue.
Good luck | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | No resister but a cracked igniter.
