| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76317 04/14/2007 3:53 AM | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | just asking, has anyone ever put a ford small block in their bolt? did not find on when i did a search. just curious | | |
#76318 04/14/2007 5:29 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Putting a Chevy SB in a stock AD frame causes some problems with steering box clearance. However the Ford SB will fit in perfectly without touching the box. I've seen one and its a nice installation. Of course now we will both be 'burned at the stake' for talking Fords on a Chevy Forum! | | |
#76319 04/14/2007 5:48 AM | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | The wood is already piled around the stake for you both....
58' 3200 235 3-speed/OD
#76320 04/14/2007 6:24 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Guys, BURNING is too fast I say draw and quarter after the rack and then burn the pieces. | | |
#76321 04/14/2007 2:55 PM | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | but it will still be a chevy, rolling down the road | | |
#76322 04/14/2007 3:25 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That must mean "rolling" as in not under it's own power! | | |
#76323 04/14/2007 3:26 PM | Joined: Mar 2007 Posts: 3,372 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,372 | This is a joke RIGHT? I mean it is a joke.. Right! Ohh I feel sick. :blat: Even F??ds use chevy engines, look under the hoods at you'r next car show.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
#76324 04/14/2007 6:20 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I know its been done. I've seen two AD trucks at car shows in the area that had Ford motors under the hood.
In both cases I talked with the owners and got a real lifted finger feel from the owners. Neither said it, but my sense were these are Ford guys wanting to fight back.
But then I frequently tell a Mercedes owner I know about how I'm putting a Chevy motor in a Mercedes. I don't own a Mercedes but it does make a good story and he sure doesn't like it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#76325 04/14/2007 8:12 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Burning at the stake? Drawn and quatered? Gee, it's become the battle of the duelling Zippo's, has it? And I thought simple shunning was the proper F*&d retaliation. That and stopping to give them a ride to town in your Chevy when the F^#d broke down.
Bur Cruzer if you want to put that thing in your Chevy go right ahead. I'll donate the tow rope. | | |
#76326 04/15/2007 3:02 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | It should have a sign on the back pitifully powered by Ford what was I thinking. | | |
#76327 04/16/2007 12:11 AM | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | well,well, well, it still, will be a ford under the hood, funny, i knew asking would be traumatic for some...thanks guys, for the input
raf | | |
#76328 04/16/2007 2:08 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This reminds me of the new Southern Motor car. They have a beautiful AD body with, as of now, a F**d motor. | | |
#76329 04/16/2007 2:15 AM | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Blasphemy I say!....May the Flint Mich. gods have mercy on thy soul!
#76330 04/16/2007 2:22 AM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Well, my F350 is about to have an identity crisis, with an Onan/Cummins turbo diesel engine, a New Process 235 transmission out of a GMC, an early Chevy hydraulic clutch bellhousing, and a GM Corporate 14-bolt rear axle. It's already worn out two 351C engines and a C-6 transmission, plus the original Ford rear axle. Most of the powertrain is out of a UPS box truck, which was set up to run the Cummins, A Chevy 292, or a Ford 300 interchangeably. The Cummins is a 120 HP turbo diesel, with a top governed speed of 3,600 RPM. It should handle a 1-ton with a 12-foot flatbed without much trouble, although I'd prefer to have an overdrive 5-speed instead of the 4-speed direct drive NP 235. Jerry
#76331 04/16/2007 3:21 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I like old rides--period. That said, we put chevy engines in where a rear sump fits best, ford where front sump is best (like mercedes), and chrysler if a center sump works. Wouldn't hesitate for a second to put a 302 ford in a cracker box chevy II since they came with a front sump engine and wouldn't spend a minute cobbling up a ford with a supposedly rear sump pan (that still has the oil pump hanging down) to keep it "all ford". Since the 283-350 has the cheapest aftermarket parts it is the one most often used and the 318-340 chrysler is the least used because of availability and parts prices. Whether anyone likes it or not, the pushrod 302 ford is one of the best engines ever because it's ITT ( impervious to teenagers). Just watch how they drive their mustangs and it'll make one cringe. Before anyone asks my personal ride which just went to a new home (due to $3 gas) was a 76 LUV with a chevy smallblock 400.
Evan
#76332 04/16/2007 5:27 AM | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I just want ya'll to know my posts where in pure jest. I am driving a 76' Ford F150 Ranger XLT that belong to my grand-father. I have lots of fond memories of riding with him in that truck to go wood cutting or what not. Some people have offered to buy and and my brother and I say, "You can't put a price on memories." I am a Chevy man first though, but glad to see people sticking with American made.
#76333 04/16/2007 4:47 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Gee Apachefiend I am glad your posts were in jest. I was starting to pack and move away.
Interesting note about engine swaps. My neighbor has one of those newer Dodge pickups, I think its a Dakota, and has just finished installing a complete SBC Chevy driveline in it. He liked the look of the truck but didn't like the engine. No kits for that conversion, all fabrication. | | |
#76334 04/17/2007 12:21 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Best conversion I've seen of late was recently completed by a neighbor/friend of mine.
He just built a 48 Ford 1/2-ton pickup on a late model Dodge Dakota frame.
All-wheel drive, and yep... It's gotta HEMI!
Very nicely done, and probably the best running Ford in the area.
He's already been contact by one of the Classic Truck mags. for a full spread and cover. | | |
#76335 04/17/2007 2:43 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Originally posted by coilover: ford where front sump is best '64-'67 Nova V8s had fron sump smallblocks. Here's a suggestion. I take this from the guys that are using the "Olds Rocket" el-fako smallblock rocker covers to pass them off as Olds engines. Make up a set of Chevy racing covers for your ford, then tell folks it's one of them ne R 07 Nascar blocks!  You can tell 'em you got it from Hendrick racing!
Bill Burmeister | | |
