4 members (HareCanvas, Steveoreno, Waveski, stlcardinalsguy), 109 guests, and 5 robots.
Topics128,184
Posts1,057,266
Members48,467
I got my new parking lenses for my 64 GMC. The lenses are attached to the bucket with a type of rivet, but what are these called? The ends need to be flared, and I could do it with a punch or something, but I'm sure there's a tool to do it. I just don't know what they are called.
A picture's worth a thousand words:
http://captaincheeto.com/pictures/64-gmc/misc/IMG_8862_1024x768.jpg
There is one place that you have not looked, and it is there - only there - that you shall find the master.
k10 Offline
Stainless nuts and bolts and some Loctite. Life is too short to worried about stuff like this.
Those are buck-rivets. With a bucking bar, which has a small divoted end, to match the head of the rivet, and an air hammer, as well as, another pair of hands, you can set those, to look like the originals.
Thank you and thank you.
k10 - it's one of those things that would bug me to the end of time if I didn't know what they were. Of course I thought of nuts and bolts. But then I'd have to make 3 trips to Home Depot and 2 to Ace Hardware to finally get the right stuff. smile
4-5-6 I am surprised there is no hand tool that can to it in one shot, it seems like something that someone would have come up with by now. But I guess there probably aren't too many of these being used today.
I think I'll try my hand at setting them by hand with what I have around, and if not go the nut/bolt route. I have some blind rivets, but there's a chance of cracking the plastic with those.
Bucking rivets is a lost art, but they are still used extensively in the aviation and marine industries, but primarily in a production environment, thus tools for doing high volume.
Was pretty much a piece of cake. I had to drill out the holes in the buckets because the new rivets were bigger than the old. The rivets were simple because - duh - they are aluminum. I just used a center punch and a rivet plate I had from some leatherworking snaps. Worked like charm. New sockets and bulbs too.
Pics:
http://captaincheeto.com/pictures/64-gmc/turnsignals/
Good job. IF they had been real hard I was going to suggest you may be able to do it on a press. It looks great.
Nice job on the re-do. This post makes me wonder why such a different approach on assembly, that is, GMC vs Chevy? It's so easy to service anything on a Chevy, and with basic tools, But GMC has plastic lenses that are RIVETED in place??
I've never owned a GMC so I must ask, is the whole truck this way?
