8 members (Hotrod Lincoln, Charles in CA, Gdads51, Cletus1950, J Lucas, dt235sd, 1955 1 Series, 1 invisible),
82
Mod | | | Forums66 Topics128,079 Posts1,056,300 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 16 New Guy | | New Guy Joined: Jul 2011 Posts: 16 | Does anyone have any suggestions on a replacement/upgrade air filter to fit the rochester carb? It has the oil fed filter on it now. Is there a benefit to keeping the old style filter on there? It seems like it would get more flow with a newer style filter. At my auto parts store the edelbrock and similar filters at sized to fit larger carbs. | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Some people modify the oil bath filter to accept a paper element, but if you keep the original filter clean and properly maintained, it's what the engine was designed to use. Why would it be necessary to flow more air? Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Some people modify the oil bath filter to accept a paper element, but if you keep the original filter clean and properly maintained, it's what the engine was designed to use. Why would it be necessary to flow more air? Jerry Truer words could not be posted. Fill with 50W oil to the marked level. It could not be any siimpler, any less expensive, and any cleaner. | | | | | Joined: Jul 2011 Posts: 16 New Guy | | New Guy Joined: Jul 2011 Posts: 16 | Ok, cool. I wasn't sure if something new would be beneficial. Should I take apart the old filter? Is there a cleaning procedure? I am not at all familiar with it. Thanks guys. | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | I removed my oil bath and installed a air filter. Its been descussed a million times. Air filters are cleaner but oil bath is old school. When it comes down to it, just use what you want. If you want more info on one over the other IM me and ill tell you. Good luck | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Right back to the same old story which is repeated a hundred times a year. These old Stovebolt’s have survived leaded gas, dirt and gravel roads, sitting out behind the barn or in a field for decades, being the subject to millions of young people learning to drive in them, having been driving by old broken down demented dirt farmers, over loaded and worked to death. They ran on five year old gas in their tanks, and old drain oil from the Farmall or what ever was setting around the garage at the time, many lost their air filter after the second winter and 95% of them never saw an oil filter and those that did very rarely had it changed because it was such a pain in the ars. But somehow they survived it all for 50, 60 or 70 years just the way they came from the factory so why does everyone want to re-engineer these trucks????? Properly restored an Advance Design Chevy truck is gonna outlast any one of us that post to this here forum! Of course as Grandpa posted, "when it comes right down to it, just use what you want." after all, millions of people did before you and hundreds of thousands of the Stovebolt’s are still running.
But now that I’ve got that off my chest, to answer your original question Father Neptune, the only way to put a new air filter element in to the original “Oil Bath” style air filter is to hack it up which just leaves one less original “Oil Bath” air filter in the world and makes my original “Oil Bath” air filter worth that much more. Or……. If you have the spark arrestor silencer type very often the original mesh is falling apart and the reproduction ones are somewhat expensive. Here you can use something like a Car Quest #87373 dry paper filter as a replacement for the mesh. This doesn’t destroy the original air filter housing and if you ever want to spend the cash and restore it using the original style wire mesh element you can. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I agree with the idea that "its lasted this long so why fix something that isn't broken."
However, what I do to my truck today exceeds what it was originally designed for. My 51 was not designed to drive down the interstate at 65-70 mph all day long, which I do.
Given that idea, when I install my PCV system on by dual carb setup, I plan to use the original style air filter. Should I convert to paper filters?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Neptune Green, seeing that you live in Rosamond sure brings back a lot of great memories for me. I was an AMA District 37 desert racer from 1968 through 2001 and drove by Rosamond hundreds of times on the way to and from the races. The California desert is a great place!
With regard to improving the breathing on your truck, the negative comments you got do not match my experiences. It's amazing how some people cling to the past with a death grip rather than try something new.
I modified the air intakes on both my '36 Chevy pickup and '71 Dodge van that I bought new and still have.
On the '36 there is a pancake looking air cleaner that originally had a metal mesh "filter". There is no way that coarse metal mesh can exclude fine dust that would act as a grinding compound inside the engine. I found a NAPA pleated paper air filter element that was a direct replacement for the metal mesh.
Oil bath air filters work by slamming the air flow against the oil embedding the dirt in the oil and causing the air flow to reverse direction. That's about as far from efficient laminar air flow as you can possibly get and does clean the air but also gives the engine asthma. Eliminating turbulent flow in favor of laminar flow improves performance. No matter how primitive an engine is, if it can breathe easier it can't help but run better.
How do I know that improving air flow into a stock engine improves performance? It's from Desert racing again. To get to the races in Lucerne Valley I used to drive my van over Cajon Pass, elevation about 4200 feet. The last few miles approaching the pass from the south are really steep and the van had to work hard hauling my family and the race bikes and pulling our little travel trailer, especially if there was a head wind.
As an experiment, I built a fresh air intake that picked up cooler air in front of the radiator and ducted it to the air cleaner snorkel. My van's speed cresting Cajon Pass immediatly increased and the added power was also very noticable while pulling the trailer into a headwind. The air flow was so much increased that larger carburetor jets were required to eliminate pinging after installing the cold air intake.
I would encourage you to use your ingenuity in making any improvements you can and see how they work out for you. It's fun!
I just converted my '36 pickup from 4.11 to 3.55 gears after being told by the "experts" that it couldn't be done. There is a detailed write up on that conversion with a lot of pictures on the 1936 Chevy Owners online forum.
Ray
| | | | | Joined: Jul 2011 Posts: 16 New Guy | | New Guy Joined: Jul 2011 Posts: 16 | Man, these kind of responses are exactly what I joined this forum for. thanks to everyone for the variety of opinion and info. I'm definitely not gonna alter the old filter, but I think after changing the oil in it I'll seek out an after market filter and compare the performance. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I didn't hack up my oil bath filter, but found an old mesh type filter in a boneyard, and put a paper element in that. Works great, and I can put it back stock anytime!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
