| | | Forums66 Topics128,060 Posts1,055,833 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | Hello, I have a noisy (squealing) clutch on my '53 GMC 1/2 ton, 228 inline 6. Before I put in a new clutch kit, I'm wondering if there is any way to get some lube in around the throw out bearing to see if that helps?
Thanks, Craig
1953 GMC half-ton
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Replace it. You'll do more damage because it is bound to fail after lubing....It already has. | | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | I figured that would be the answer - but it never hurts to ask, right?
Thanks, Craig
1953 GMC half-ton
