6 members (Stan 58, 46 Texaco, RoadsScholar, Otto Skorzeny, Peggy M, 1 invisible), 127 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#762534 07/14/2011 10:41 PM
I have my 261 block at the shop and want to take the flywheel and pressure plate to them but when i got this project it also came with a 235 and the po put them into the same box. The one on the left has the #s in the picture on the flywheel the one on the right has smaller #s that i can not make out yet. so can any one tell from the pics what is the 261 or the 235
FLYWHEEL PICTURES
I may be wrong, but the 261 probably has a bigger clutch. Simply measure across where the disc has run and measure it. The 261 should have a wider area. I have a 261 in my 1/2 ton and used the 261 flywheel with the bigger clutch. The foot starter works fine with it.
From the pic it looks like both are drilled for an 11" clutch, so either one would work.
There may be a difference in the timing ball placement between the two flywheels, but that depends on what year they are.
My Blog
If that visible Flywheel number is 839754 that according to my Master Parts Catalog is a 1942-51 ALL PASSENGER and 1/2T Commercial(heavy duty clutch}
(except P.G.) flyywheel. So it is likely for a 235 although it could be for a 216 not 261.
Drew
Drew's post reminds me of another point, one flywheel may have 6 volt starter teeth and the other 12 volt.
You want to match the flywheel with the starter you plan to use.
My Blog
Ring gear tooth count is the most important thing here. The 6 volt ring gear has 139 teeth and the 12 volt ring gear has 168 teeth. The flywheel has to match the starter you are going to use, 6 volt - 139 teeth, 12 volt - 168 teeth. After that is decided, then you can move on to the other issues.
The flywheel Drew P mentions will be 6 volt only. You will need a later model flywheel from either the 235 or the 261 - 55 to 62 for a 12 volt application.
Thanks for all the info, They have the same amount of teeth 139 the 235 is from 55 and the 261 is a 55 also. The truck is a 49 3100 still 6V, that had the 235 in it but PO pulled it and was going to put in the 261. so i am thinking that the 55 261 was also 6v if it has the same flywheel. and i can use the plate from the 235 that was in the truck.
