1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
I installed a new master cylinder on my '54 Chevy truck and in the process broke one of the hard brake lines at the point where it leads out of the MC. Doe anyone have a good recommendation on fixing this? can I "couple it with a flexible hose?
Carlos
I wouldn't do that unless the flexible hose is a commercial flexible brake hose with the proper fittings. It sounds like you will need to replace that line back to where is connects to a junction block. Your FLAPS should sell replacement lines by the foot with fittings.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Your '54 should have a tee out the back of the master cylinder. The line that goes around the left side of the MC supplying the left front wheel cylinder is about three feet long. The one that loops around and follows the cross member to the tee on the right side of the frame supplies the right front and two rear wheel cylinders and is about four feet long.
You can get new pre-made lines at any FLAPS or farm supply that will get you close to the correct length. Or you can order pre-made lines the are bent to fit from several companies such as Inline Tube, Classic Tube and almost all of the vendors carry pre-bent brake and fuel lines for the AD trucks.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks for the quick responses. I will head over to my local auto parts store at lunch.
Cheers,
Carlos
