0 members (),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | I installed a new master cylinder on my '54 Chevy truck and in the process broke one of the hard brake lines at the point where it leads out of the MC. Doe anyone have a good recommendation on fixing this? can I "couple it with a flexible hose?
Carlos | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I wouldn't do that unless the flexible hose is a commercial flexible brake hose with the proper fittings. It sounds like you will need to replace that line back to where is connects to a junction block. Your FLAPS should sell replacement lines by the foot with fittings.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Your '54 should have a tee out the back of the master cylinder. The line that goes around the left side of the MC supplying the left front wheel cylinder is about three feet long. The one that loops around and follows the cross member to the tee on the right side of the frame supplies the right front and two rear wheel cylinders and is about four feet long. You can get new pre-made lines at any FLAPS or farm supply that will get you close to the correct length. Or you can order pre-made lines the are bent to fit from several companies such as Inline Tube, Classic Tube and almost all of the vendors carry pre-bent brake and fuel lines for the AD trucks. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks for the quick responses. I will head over to my local auto parts store at lunch.
Cheers,
Carlos | | |
