1 members (WICruiser), 209 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
Hi there, Are the 4 wire terminal blocks the same length as the three wire? I have the three wire on my truck, but when I added the parking lights, I had to use a connector because I didn't have a place on the terminal block. Can I switch them out, or do I have to drill holes?
Hi, pplummer, No, they are different lengths. On my 49 canadian 49 there are two raised bosses on the inner fender close to the radiator that you use to bolt the connector block to. Only the three wire block will fit. One to high beam, one to low beam one to Park/running lights ( the lights in the upper part of the grill). For my turn signal lights I added a connector. Note: I had ordered a harness with turn signal wires included.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
That's what I did (added a connector) but if I could (which I guess I Can't now without it shorting out) I would have.
