0 members (),
136
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76205 04/11/2007 4:52 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I started up an engine that hadn't been run in a while. It's got about an hour on it now. On start, choke pulled out, it starts right up, abut smokes a lot. If you hit the throttle you get enough smoke to kill all the mosquitoes in the neighborhood. With the choke in it still smokes on acceleration. It's a dark grey smoke as opposed to white or blue. Could it just be a tuneup is needed?
"Happiness equals reality minus expectations" - Tom Magliozzi
#76206 04/11/2007 5:35 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim Bow,
Dark grey smoke is a weird color to troubleshoot. I would run the rig for awhile and see what 'cooks off'. If the smoke doesn't smell of raw fuel and the truck is throttle responsive, I can't imagine what would produce that color 'bug bomb'.
Stuart | | |
#76207 04/11/2007 5:25 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Dark grey smoke sounds like excess fuel, much the same as blue smoke. As long as it's not white smoke (steam) you don't have a major problem. I'd look at the carburetor as the villan here, probably needs a good cleaning. | | |
#76208 04/11/2007 5:45 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I agree with Chevman. It does sound like she's running a little on the rich side. What does the exhaust smell like? That's usually a pretty good hint as to what needs tweaking. I'd check for carbon on the plugs, too. That'll tell you for sure whether or not you've got an excess fuel problem. A tune up will never hurt anything, though. I generally give any engine I'm waking up after a long nap a tune up anyway -- just to make sure that she'll fire without ****ing me off. ~#~#~#~#~ Something else that might cause grey smoke: Did you have any head work done? Sometimes that coating they put on there makes copious amounts of stinky grey smoke. It usually burns off pretty quick, though. Usually within the first 10 minutes, but sometimes -- if it's cold out -- it takes a few more minutes for it to get hot enough to burn off. | | |
#76209 04/11/2007 6:23 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim Bow,
Can you reveal the ID of the mystery engine!
Stuart | | |
#76210 04/11/2007 6:46 PM | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If it's a chevy transmission, powerglide,350 turbo,or 400 turbo it will stop smoking when it runs out of transmission fluid. the vacum modulator is leaking and trans fluid is being sucked into the intake manifold.
Tommy 59 apache 1/2t 261 short stepside | | |
#76211 04/11/2007 10:11 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I can't help you with your problem, but I hope it gets resolved. I have a 74 Nova with a 350 that doesn't smoke at ALL until you drop it down in 2ND and stomp the gas., then I get that same black/gray smoke. I've tried everything and it still does it.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#76212 04/12/2007 1:59 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | don't know about grey smoke but i've always went by, blue=oil, white=water, black=fuel........ | | |
