3 members (wilbur53, MickeyP, dt235sd), 59 guests, and 0 robots.
Topics128,049
Posts1,055,552
Members48,425
#761964 07/13/2011 3:15 AM
Does anybody know how to take off the box and mounts? i took a look and thought they were just bolted onto the frame but they seem to be riveted in......
If it is in fact riveted, and I think they all were, you're looking at drilling out those rivets. If you have access (like cab is off the frame) grind the heads off, center punch, and drill away! Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I was looking at the same thing and concluded that it would be best to leave it in place and accept it as a job condition.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
i guess i'll have to wait until i can take her into the shop haha, my box is slowly rusting away
I use my grinder and grind-ed off the heads and a large center punch and a 5# sledge hammer to knock the rivet out. Then I bought one of these: CCP
~Jim
I have read various recommendations that if you are doing a full tear down, to remove all the rivets (factory assembled) and replace with bolts. Particularly for the battery tray, running board brackets, etc.
I haven't started on replacing my bent battery tray and running brackets yet. P.O. got into several bumps and scrapes in his farm truck!
Dave Baird
1951 Chevy 3803
i used an air chisel where i could. where i couldnt i did it the old fashion way with a hammer and hand chisel. once the box was removed i just puncheed out the stumps that remained.
I use my plasma cutter and in a couple of seconds the rivet was off and that wad on my 1950 chevy pickup.
What's a "wad"
~Jim
"wad"... it was suppose to be "was" but i pressed the D on accident.
