7 members (GMCJammer51, DaveV, Phak1, 1955 1 Series, Guitplayer, Gdads51, Napco Man), 77 guests, and 1 robot.
Topics128,132
Posts1,056,732
Members48,454
#76185 04/11/2007 3:58 AM
I am putting a 250 in my 52 GMC to replace the 228. I did a search to find out if the bellhousing bolt patterns are the same on the 228 and the 250. I couldn't find out what I need to know. I know that I will have to convert to side motor mounts. If the bellhousing will bolt up, then I will fit a borg warner T 10 to the stock bellhousing using the tricks that make the T 5 swap work. Am I off base here or should I use the bell housing that is on the 250 and use a tranny mount along with the new side mnunts for the engine?
#76186 04/11/2007 5:17 AM
You'll need a 250 bell housing.
#76187 04/11/2007 5:35 AM
Quote
I don't know what bell housing you have on the 250. If you use the correct early V-8 type bellhousing, which could be on the 250 already, and change to a '54-'55 1st bellhousing crossmember (or make up some mounts) you can use your T-10 without a lot of tricks. You will have to change to an open rear.
But as Cletis said you can not use the 228 bellhousing on the 250.
#76188 04/11/2007 6:31 PM
Does anyone know if the 55 pass car bell housing is the same for the 54-55 1st? Thanks!
#76189 04/11/2007 9:11 PM
Riding in the Passing Lane
The 6 cyl. will enterchange but will not fit the 250. The v-8 will fit the 250 engine. You can do like Oldsub say,s & get a 54-55 1st crossmember or wack your crossmember up & put one under the engine & one under the rear of the trans. Then you have to change to the open drive shaft.
1972 Chevy c10 Cheyenne Super
#76190 04/12/2007 4:20 AM
OK ! Thanks for the help, gentlemen. I( think I've got it straight. Now I've got to deceide which to do, find the right bell housing, or cut up the existing crossmember.
I know where I can get a 55 v 8 bellhousing from passenger car, but will have to look for the proper crossmember.
I've got a 12 bolt ready to install as well.
