| | | Forums66 Topics128,089 Posts1,056,353 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76185 04/11/2007 3:58 AM | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | I am putting a 250 in my 52 GMC to replace the 228. I did a search to find out if the bellhousing bolt patterns are the same on the 228 and the 250. I couldn't find out what I need to know. I know that I will have to convert to side motor mounts. If the bellhousing will bolt up, then I will fit a borg warner T 10 to the stock bellhousing using the tricks that make the T 5 swap work. Am I off base here or should I use the bell housing that is on the 250 and use a tranny mount along with the new side mnunts for the engine? | | |
#76186 04/11/2007 5:17 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You'll need a 250 bell housing. | | |
#76187 04/11/2007 5:35 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by smittyschevy: should I use the bell housing that is on the 250 and use a tranny mount along with the new side mnunts for the engine? I don't know what bell housing you have on the 250. If you use the correct early V-8 type bellhousing, which could be on the 250 already, and change to a '54-'55 1st bellhousing crossmember (or make up some mounts) you can use your T-10 without a lot of tricks. You will have to change to an open rear. But as Cletis said you can not use the 228 bellhousing on the 250.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#76188 04/11/2007 6:31 PM | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Does anyone know if the 55 pass car bell housing is the same for the 54-55 1st? Thanks! | | |
#76189 04/11/2007 9:11 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 6 cyl. will enterchange but will not fit the 250. The v-8 will fit the 250 engine. You can do like Oldsub say,s & get a 54-55 1st crossmember or wack your crossmember up & put one under the engine & one under the rear of the trans. Then you have to change to the open drive shaft. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#76190 04/12/2007 4:20 AM | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | OK ! Thanks for the help, gentlemen. I( think I've got it straight. Now I've got to deceide which to do, find the right bell housing, or cut up the existing crossmember. I know where I can get a 55 v 8 bellhousing from passenger car, but will have to look for the proper crossmember. I've got a 12 bolt ready to install as well. | | |
