3 members (2-Ton, Ponchogl, 1 invisible),
363
Mod | | | Forums66 Topics128,160 Posts1,057,050 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | My truck has developed a leak at the carrier bearing area (it drips from there) I have the stock set-up with the ball on the trans end and the carrier bearing at the intermediate point. Is there a simple fix for this? I have taken it apart during the restoration to clean and paint but the carrier itself was sealed (I did not disassemble it)? It is actually dripping from the bracket in the attached picture, more annoying that a problem but was wondering if there was a fix. http://community.webshots.com/photo/2097945860102454676FGTFFn | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I can't help with your leak Brad but wanted to compliment you on the exhaust clamp. Nice!
Chuck | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | It can leak from there?!? Isn't it just a grease fitting there?
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That seal is leaking Brad. Had the same trouble with mine when I first brought it home. It’s a lot of work to change it but these pictures might help. http://www.pbase.com/dennygraham/driveline As long as you're puking fluid out of that center support keep an eye on the trans fluid, it will suck a bunch out thru the rear bearing and you don't want to run it low. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't have a 3/4 Ton but here is what I see from the manual. Fig 79 on page 4-52 shows the driveline from the ball back past the center hanger, open universal and slip joint. Your torque tube extends back from the ball and ends inside the center hanger assembly. There is a seal in there and if it leaks, it will leak out of the center hanger area. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's what the pictures show Fred, this one in particular shows the seal which is behind the drive shaft bearing. http://www.pbase.com/dennygraham/image/120617210Denny Graham Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Denny,
Thanks for the reply and the heads-up is the seal available at the local Flaps or did you order it from one of the vendors? Denny I went through the pictures and they will help a ton although I can't build tools like you! Can you clarify for me the proper seal number that you found?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Okey dokey Brad, sorry it took so long to come up with an answer fur ya, but here is a better picture of the correct seal. http://www.pbase.com/dennygraham/image/136368093/large Blow it up by clicking on the 'original' button at the bottom of the picture and you can clearly see the numbers on the seal. This seal can be ordered from your local bearing supply house such as: Motion Industries 1414 S. GLADIOLA ST. SUITE 300 SALT LAKE CITY, UT 84104 Phone: (801) 972-1036 The seal on the right was one that was damaged when inserting the drive shaft the first time I replaced the original one. That's very easy to do with this enclosed front drive shaft. I replaced it again a short while ago and it doesn't leak now. In this picture the seal on the left is the seal that the vendors are selling, it’s to thin. The seal on the right is the OEM seal. The 470394 Timken/National Seal is an exact replacement of the proper dimensions: http://www.pbase.com/dennygraham/image/120617165 To service this ¾-ton front enclosed drive shaft does require that some tools need to be fabricated. It isn’t an easy repair for sure. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Thanks Denny I will have the seal ready for when winter hits and the truck is parked that way I can take my time on it. In light of the tools do you think a good driveline shop could do the install? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't see why a completent shop couldn't install the seal and make sure and have them check the bearing while they had it apart. But I would order the 470394 seal, might want to keep an extra just in case they did screw it up. As I said, that's easy to do when you insert the splined shaft back into the housing. Denny Graham Sandwich, IL
