9 members (sron48, rfs56trk, Mike in Sycamore, Nick in Manitou, Otto Skorzeny, Bill Hanlon, Charles in CA, 2 invisible),
99
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76157 04/10/2007 4:00 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | Aaaaah! Ok, I have been told this Thing is a 216, 235, and a 261. "I" dont know. Here is a link to the eng. pic http://groups.msn.com/acmountainviewranch/thingsphotoalbum.msnw?action=ShowPhoto&PhotoID=322 Now, Thing is a 1953 3800 1 ton. He has a 3 speed and I am "told" he has a 488 rear. I dont know if any of these are original. I assume so, but what do I know? Things odometer reads over 94K, and it does roll still. I am keeping the engine as it is still strong, but I need a new gasket as he has a leak. I would like to change out rear and tranny, any suggestions on that? (to make a better driver) Ok guys! have fun, let me know what Thing is!
Chey LOST1953 My favorite color is CHROME The ugliest trucks are driven by the prettiest girls  I dont suffer from insanity, I enjoy it! O Lord, WHY did I buy another "Thing"? (again??) ---- 1953 Chevy 3800 1-ton Gallery More photos at MSN ----
#76158 04/10/2007 4:22 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I think you can eliminate the 216 by the way the valve cover is mounted but here's how to tell for sure: Look at the numbers stamped on the flat area just behind the distributor - then - you can follow the links under tech tips to i.d. it or just post them back on here and one of these experts can decode it for you. | | |
#76159 04/10/2007 5:55 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just judging from the rocker cover, I'd say it's a '58-'62. All of the '55-'57 235/261 engines I've seen have the filler at the front of the cover, the '58 and later seem to be all to the center. Looks like the radiator has been changed, too. The upper hose should be lined up straight with the neck on the engine, not at an angle. In addition to the # by the distributor, there's also a casting date above the starter that will narrow things down as well. For the rear gears, you'll have 5.13s. That's the only gear ratio that was used on those trucks, unless the center section was changed to a 3/4 ton, then it's most likely a 4.56. It should have a 4 speed, but there was a somewhat rare option of a heavy duty 3 speed in the 1 ton.
Bill Burmeister | | |
#76160 04/10/2007 6:16 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | http://groups.msn.com/acmountainviewranch/thingsphotoalbum.msnw?action=ShowPhoto&PhotoID=325 here is a link to Things #'s. I have also posted side pics of eng as well. I know, that hose needs fixed and radiator as well. The fan on it (now) sticks out to far to put the original sized rad. in. So I have to change that as well (plugs/wires/dist, and I am sure other stuff as well)
#76161 04/10/2007 6:29 PM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | If it's a 235, shouldn't a "235" be stamped on the side of the oil pan? Wouldn't hurt to check and see. Wada | | |
#76162 04/10/2007 6:49 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | ***Going to crawl under truck...again...***
#76163 04/10/2007 7:57 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just from the casting # by the starter, the block was cast June 9 of '58. If you can get the # that's stamped on the pad directly behund the distributor, that will tell exactly what the engine is. I'd also like to add that I've never seen a full pressure 235 with anything stamped on the pan to give engine size. I think that only applies to the babbit pounders.
#76164 04/10/2007 10:59 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
#76165 04/11/2007 12:33 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Since your temperature gauge has an adaptor fit to it instead of going right into the head, its definately not a 216.
I can't quite make out the casting number on the head, but it looks like the valve cover was set up for PCV at one time.
#76166 04/11/2007 9:20 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | so, we have eliminated the 216, but 235/261????
#76167 04/11/2007 9:46 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | when i zoom in on pic. it gets pretty blurry but i think you got a 261. right above the starter it looks like it has the captains bars. that would be a 261... | | |
#76168 04/11/2007 10:12 PM | Joined: Oct 2005 Posts: 37 Apprentice | | Apprentice Joined: Oct 2005 Posts: 37 | I have a 235 in my bolt...and it doesn't look like that one...process of elimination. Take a look at my pics...I have acouple of the 235 when I pulled it out...and as I am rebuilding. Enjoy! | | |
#76169 04/12/2007 12:50 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Chey:
Could you post the number on the boss just aft of the distributor?
You may need a wire brush to get to it.
That should tell us once and for all what year and application this block is. | | |
#76170 04/14/2007 3:08 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | | | |
#76171 04/26/2007 2:59 AM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 |
#76172 04/26/2007 4:40 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I previously posted: Chey:
That should tell us once and for all what year and application this block is. :confused: | | |
#76173 04/26/2007 1:52 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I'm going through the same identification issue with the engine in my 1951 4400. The problem is complicated by the fact that its a re-manufactured engine, most likely a 1954.
The 3836848 cylinder head casting number is one that I did a lot of research on yesterday. These seem to have been the heads of choice because they had a slightly smaller combustion chamber than the others. Higher compression ratio = more power if it doesn't have pre-ignition problems.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
#76174 04/26/2007 3:57 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | That looks more like one of the newer style sixes. What are they? like 290s or some thing?
"It ain't a truck if you can't hose out the cab."
#76175 04/26/2007 11:38 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 |
#76176 04/26/2007 11:52 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | AND F6IOJ (the I may be a 1?)
