| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | My question may seem simple to answer, but not to me.
My zenith 28 carburetor appears to be leaking from the main jet plug. I put a wrench on the plug and noticed it was loose. I started to tighten it but turned it back, thinking it may affect the carburetor performance. I bought a carburetor rebuild manual but I can't tell if this plug can be tightened or it is an adjustment.
So, can I tighten this plug without affecting the carburetor performance?
Thanks, Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Here is picture of the nut I am talking about. http://i824.photobucket.com/albums/zz168/dinlow/zenithcarb.jpgI think the answer is "Yes".
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | There's a gasket under it, so that one is simply a plug. Tighten it. Some Zenith carbs had adjustable main jets, with a knurled knob in approximately the same position as the plug yours has. Your carb probably has a fixed-size jet that's accessible by removing the external plug. Jerry
