3 members (Wickedbass, Nick in Manitou, JW51), 93 guests, and 2 robots.
Topics128,066
Posts1,055,876
Members48,428
#761470 07/11/2011 2:55 PM
My question may seem simple to answer, but not to me.
My zenith 28 carburetor appears to be leaking from the main jet plug. I put a wrench on the plug and noticed it was loose. I started to tighten it but turned it back, thinking it may affect the carburetor performance. I bought a carburetor rebuild manual but I can't tell if this plug can be tightened or it is an adjustment.
So, can I tighten this plug without affecting the carburetor performance?
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
Here is picture of the nut I am talking about.
http://i824.photobucket.com/albums/zz168/dinlow/zenithcarb.jpg
I think the answer is "Yes".
-Unknown-
There's a gasket under it, so that one is simply a plug. Tighten it. Some Zenith carbs had adjustable main jets, with a knurled knob in approximately the same position as the plug yours has. Your carb probably has a fixed-size jet that's accessible by removing the external plug.
