3 members (Gdads51, UtahYork, 1 invisible),
109
Mod | | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76106 04/09/2007 4:47 PM | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | I am piecing together a 292 in a 66 C-10. The double groove damper and water pump pulley align perfectly. I am certain they are both correct. This is the damper that has about 1/2" space aft. The alternator is not lining up with them. I am using an alternator bracket that came off a 250. My question is...was there a unique alternator bracket for the 292 that would move the alternator farther forward 1/2"? Or was there a different pulley with an extra 1/2" spacing that accomplished this? | | |
#76107 04/09/2007 5:13 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you'll have to make a crankcase bracket to move the alt forward. mine is 3/8'' plate 2''x6'' w/ 4 hole threaded into it it's no big deal really
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#76108 04/09/2007 5:53 PM | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | I am trying for an all original setup. Trying to figure out what it looked like out of the factory. | | |
#76109 04/09/2007 8:03 PM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If memory serves me correctly, the original alternator had a pulley that the groove for the v belt was about a belt thickness further away from the alternator than most are. I used to work on 292's in school busses years ago, and if an alternator went out, I always wound up changing the pulley to make it line up. | | |
#76110 04/09/2007 8:12 PM | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Thanks Roy. So the mounting bracket I am using from a 250 is probably usable and not the problem? Guess I need to locate a correct pulley then. | | |
#76111 04/09/2007 8:14 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | chances are the 250 pulley is for a 250 and may not work correctly for a 292
#76112 04/09/2007 8:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 292 used a cast iron lower bracket. It was spaced different than the 250. The pulley also was spaced out like Roy stated. 75 up used the narrow belt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#76113 04/09/2007 9:11 PM | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Thanks Wrenchbender. I have a cast iron lower bracket, but I assumed it wasn't correct since I couldn't get the alternator to align with the other pulleys. So unless there is more than one type of cast iron bracket that was used, then I probably have the right one. If anyone has a lead on the correct pulley I would appreciate it. | | |
#76114 04/10/2007 5:09 PM | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | I have installed the alternator using the lower cast iron bracket. Where does the upper bracket attach to the block? There are no holes for it, except to use one of the water pump bolts, but even that doesn't really sit right. Is this correct? | | |
#76115 04/10/2007 8:40 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It goes in one of the water pump bolts but I think it is different than the 250. Be shure & use a longer bolt preferably grade 8. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#76116 04/17/2007 6:01 AM | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | Thanks to a number of Stovebolters, here is the complete answer for anyone who may encounter this problem in the future...
The correct alternator bracket is cast iron, and has cast number 3831195. This bracket will provide a more forward offset than the stamped, spot welded bracket probably found an a 230/250. Additionally, the OEM 292 uses a unique alternator pulley that has about an extra 1/2" of spacing forward from the alternator fan. If you do not have this pulley, and simply purchase a rebuilt OEM alternator from a local parts store (#7122 in my neighborhood), it will not come out of the box with the right pulley. A special note of thanks to Mr. Larry G. in Oakdale, CA for hooking me up with that pulley. Everything lines up perfectly now, with all OEM parts, just the way it rolled out of the Fremont plant on 9-15-65. | | |
