6 members (Ridgeback, Gdads51, carbking, Jon G, 55shaker, 1 invisible), 61 guests, and 2 robots.
Topics128,268
Posts1,058,391
Members48,485
#760652 07/08/2011 4:32 AM
hey guys, brought home an s10 t5 today for my 292 but the bell housing is different,did i need the bell housing from the old sm465 to do this swap?
tyler h #760831 07/08/2011 10:51 PM
Riding in the Passing Lane
No. The SM465 has a larger opening around the front brg. retainrer. I dont know what year you have but 67 on back had the smaller hole. With the proper mods. to the trans & clutch as desctribed in Tech tips & past posts it should fit.
1972 Chevy c10 Cheyenne Super
okay, i have been told that the bellhousing from the 292/sbc will work on the t5
tyler h #760844 07/08/2011 11:37 PM
The bell houseing from the S-10 will not work unless it happens to be a 4.3 engine. Any chev. bell housing will fit the engine except the old Stovebolt 6 engines 62 on back.
hmmm, i got the t5 from an 86 s10 because it has the gear ratios i wanted and the mechanical speedo, but of course the bell is wrong. if i were to get a 4.3 bell will that solve my issues?what about the hyd. slave cyl?
tyler h #760953 07/09/2011 1:20 PM
You can take the bellhousing off the transmission you have. Then just find a later GM bellhousing. Unless you want a hydraulic clutch setup don't worry about finding one of those.
don stocker #761131 07/10/2011 2:02 AM
You don't have to run a hydraulic throw-out bearing or hydraulic activated clutch. If you're going to use an old stock manual bell housing, why not use the stock fork, diaphram pressure plate with your stock flywheel, a long throwout bearing and a clutch disc from an 83-84 2.8L Firebird. It takes a little fabricating on the bell-crank assembly but with a mechanical setup you save having to bolt the master/slave cylinders or buying a pricey hydraulic bearing. I've got 14K on my mechanical setup with no issues.....clutch action is as smooth as butter. Check out pics in my webshots Chevy albums.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
i am currently working on the my 4th ad truck with a late model 6 (250 or 292) and a t5 trans you need the following parts for a clean installation 54-55.1 bellhousing crossmember, 55 chevy truck v8 bellhousing, 54 and up bellhousing mounts, boxing frame plates, side motor mounts (i make them to use the biscit style rubber mounts), and a side plate to mount on the block to mount your original gas peddle linkage, modify your trans, and get a clutch disc, look on chevybombs.com my user name is THE CUT MASTER my work is document there.
1949 SUBURBAN
john romero #761397 07/11/2011 3:24 AM
thanks guys, i'm just sick that i got rid of the old tranny and clutch stuff,live and learn!i'll check out your stuff john,looks like good info.i am putting this stuff in a 50'1/2 ton so i'd rather not mess with the hyd.clutch stuff.there is a 66'big bolt at picknpull with a 292/4spd that i'm hoping they will put in the yard(thank god for picknpull!)maybe i can get what i need there.
