8 members (Ridgeback, carbking, Gdads51, Jon G, 55shaker, Jay R, Oswald, Joe H),
69
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | hey guys, brought home an s10 t5 today for my 292 but the bell housing is different,did i need the bell housing from the old sm465 to do this swap? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. The SM465 has a larger opening around the front brg. retainrer. I dont know what year you have but 67 on back had the smaller hole. With the proper mods. to the trans & clutch as desctribed in Tech tips & past posts it should fit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | okay, i have been told that the bellhousing from the 292/sbc will work on the t5 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The bell houseing from the S-10 will not work unless it happens to be a 4.3 engine. Any chev. bell housing will fit the engine except the old Stovebolt 6 engines 62 on back. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | hmmm, i got the t5 from an 86 s10 because it has the gear ratios i wanted and the mechanical speedo, but of course the bell is wrong. if i were to get a 4.3 bell will that solve my issues?what about the hyd. slave cyl? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You can take the bellhousing off the transmission you have. Then just find a later GM bellhousing. Unless you want a hydraulic clutch setup don't worry about finding one of those. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You don't have to run a hydraulic throw-out bearing or hydraulic activated clutch. If you're going to use an old stock manual bell housing, why not use the stock fork, diaphram pressure plate with your stock flywheel, a long throwout bearing and a clutch disc from an 83-84 2.8L Firebird. It takes a little fabricating on the bell-crank assembly but with a mechanical setup you save having to bolt the master/slave cylinders or buying a pricey hydraulic bearing. I've got 14K on my mechanical setup with no issues.....clutch action is as smooth as butter. Check out pics in my webshots Chevy albums.
Dave | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i am currently working on the my 4th ad truck with a late model 6 (250 or 292) and a t5 trans you need the following parts for a clean installation 54-55.1 bellhousing crossmember, 55 chevy truck v8 bellhousing, 54 and up bellhousing mounts, boxing frame plates, side motor mounts (i make them to use the biscit style rubber mounts), and a side plate to mount on the block to mount your original gas peddle linkage, modify your trans, and get a clutch disc, look on chevybombs.com my user name is THE CUT MASTER my work is document there. | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | thanks guys, i'm just sick that i got rid of the old tranny and clutch stuff,live and learn!i'll check out your stuff john,looks like good info.i am putting this stuff in a 50'1/2 ton so i'd rather not mess with the hyd.clutch stuff.there is a 66'big bolt at picknpull with a 292/4spd that i'm hoping they will put in the yard(thank god for picknpull!)maybe i can get what i need there. | | |
