0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#760578 07/07/2011 11:09 PM
Hello,
So what all is involved in replacing the throw out bearing on my clutch? I'm guessing I need to check the bearing and ball, and fork, but I've never worked on trannies before. My shop guide isn't very specific on these parts or process, either.
Thank,
Craig
1953 GMC half-ton
Obviously you must remove the transmission first. While not a difficult job it is time consuming and heavy. So while you are at it replace the whole clutch assembly. If the throwout bearing is shot you can expect the rest of it to be on the way out.
Riding in the Passing Lane
If it a 4 speed its kinda tough like Cletis says. If its a 3 speed it is a lot easier especially if you are a pretty stout fellow.
1972 Chevy c10 Cheyenne Super
Replace the entire clutch or just the T.O. bearing and clutch disc?
~Jim
For $150 to $180 you can get it all in a kit from any parts store. I got mine from O'Reilly for $150, it even included the plastic alignment shaft for centering the disk. Parts from South America, probably better than China. Don
Removing a SM420 transmission is pretty straight forward in order for you to replace the throw out bearing and yes the clutch. A nice weekend project. You can do it yourself with the help of a tranny jack but it's more fun and smart to have a friend under the truck with you.
Craig
