| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76064 04/08/2007 3:14 PM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | is there any way to id the year of a GMC truck frame? It is 116 inch wheel base,torque tube 248 cubic inch engine 3 speed trans. Thanks Wayne | | |
#76065 04/08/2007 3:52 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy masseyharris, I believe that would be a 47-54 frame, hope that helps. [P.S. I'm in Rosedale] | | |
#76066 04/08/2007 4:59 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Tube shocks or lever?
Huck brakes or Bendix?
Which bellhousing crossmember does it have?
If it has a 248 it must be a US made truck, not a Canadian.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#76067 04/08/2007 11:59 PM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | it has bendix brakes,tube shocks | | |
#76068 04/09/2007 2:56 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Okay so its no older than 1950 based on the tube shocks.
Are the pads on the bellhousing crossmember flat or angled? Flat means its a '50 to '53, while angled would mean '54 or '55 1st.
How close do you need to be?
