2 members (Otto Skorzeny, baldeagle), 107 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#76064 04/08/2007 3:14 PM
Junior Member
Junior Member
is there any way to id the year of a GMC truck frame? It is 116 inch wheel base,torque tube 248 cubic inch engine 3 speed trans.
Thanks Wayne
#76065 04/08/2007 3:52 PM
3B Offline
Hy masseyharris, I believe that would be a 47-54 frame, hope that helps. [P.S. I'm in Rosedale]
#76066 04/08/2007 4:59 PM
Tube shocks or lever?
Huck brakes or Bendix?
Which bellhousing crossmember does it have?
If it has a 248 it must be a US made truck, not a Canadian.
#76067 04/08/2007 11:59 PM
Junior Member
Junior Member
it has bendix brakes,tube shocks
#76068 04/09/2007 2:56 AM
Okay so its no older than 1950 based on the tube shocks.
Are the pads on the bellhousing crossmember flat or angled? Flat means its a '50 to '53, while angled would mean '54 or '55 1st.
How close do you need to be?
