8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible), 57 guests, and 4 robots.
Topics128,075
Posts1,055,919
Members48,429
#76056 04/08/2007 1:09 AM
The main bearings on my 60, 235 need replacing. Does anyone know how to decipher the codes on the back of the bearing? I of coarse need to know what size to put in. I thought it would state std, -20, etc on the back but it doesn't. well, maybe it does. There is a 7-30 mixed with all the rest of the numbers. Thx.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#76057 04/08/2007 6:15 AM
Glenn,
In order to put new mains in your truck, aren't you going to have to pull the crank? This would be the time to 'mic' it and compare the reading to a stock journal size. A visit to the local automotive machine shop for some first hand knowledge wouldn't hurt either.
Stuart
#76058 04/08/2007 3:08 PM
Junior Member
Junior Member
you will have to use a ball micrometer to check thickness
#76059 04/08/2007 6:33 PM
Just use a the pointed part of a dial caliper to measure the crankshaft diameter after you get the first bearing out. You'll be able to get a close enough estimate of the diameter to figure out if it's undersize or not. There are .001" and .002" undersize bearings available to compensate for minor crankshaft wear without regrinding, IF the crank isn't worn egg-shaped. Be sure you don't create a tight spot if you use the 1 or 2 under bearings, however. I always check for proper clearance with Plastigage when I'm replacing bearings without a full teardown and regrind.
PS: If the bearings are factory original to the engine, they probably won't have an undersize stamped on them, just a part number. That would probably mean they're standard size, but don't guess, measure!
#76060 04/09/2007 2:12 AM
Thx guys, I'll will measure the crank. I have two engines, a 51 and a 60. The bearings on the 51 looked brand new. The 60 bearings are shot.Lots of copper. Neither set gives a size. I know the 60 was rebuilt and I can't believe the 51 wasn't. The 51 plastigage to .002. I don't need to replace them but I do on the 60.
Glenn,
1952 Chevy 1/2-Ton
