Those vacuum motors are relatively tough, I bet it is just stuck. I took mine apart quite a while ago and I seem to remember it was pretty simple. The hardest part was getting it in and out. After a good cleaning and lube it worked better than when I first got the truck. Do a search here, you should be able to find something on how to rebuild it.
