| | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Hi from at last sunny England I need some advise please i have a 54 3100 with a 76 camaro front clip, i need to change the sway bar bushes. i measured the bar to be 15/16", so ordered camaro bushes to fit a 15/16" bar with mounting tabs on the clamps (moog part number k5241). when looking at the new bushes and test fitting them on the bar, the holes in the bushes are only about 3/4" so to close up the bush it will have to go about 3/8" is this normal? It seems that the bush clamp is going to struggle to close up this difference without stripping the bolt holes in the chassis Any advise would be good
Keith
if it ain't greasy it ain't diddly
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | I looked on napas website and for a 76 camaro with a 15/16" sway bar...the ID. of the rubber bushing itself(with mounting tabs) is .813" which is really close to your 3/4" measurement...I also typed in moog k5241 into yahoo and several sites said sway bar bushings for 15/16" or smaller sway bars...I'd say you got the right ones.I'd put them on.......dave
1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Thanks for that i will whack them on then!
