0 members (),
234
9
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 47 | Hi Guys,
I have a 58 chevy 2 ton. I am changing wheels and tires and am now trying to get the inner duals off. The stud has what appears to be a 1-1/8 by 16 threads and on the outer end of the stud it is square. I got the outers off but the inners seem to still be quite tight. Is there something more I need to do to loosen the inner wheel? thanks for your help!
Harrydale | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With a 13/16" square socket remove the inner nuts. Be aware that you probably have left-hand threads on the left side of the truck, and right on the right.
Grigg | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | put an appropriate size wrench on that square end and take off the studs [caps over the actual studs really], which are the 'lug nuts' for the inners
Bill | | |
