2 members (Charles in CA, Otto Skorzeny), 310 guests, and 7 robots.
Topics128,078
Posts1,056,031
Members48,433
#759960 07/05/2011 4:04 PM
Hi Guys,
I have a 58 chevy 2 ton. I am changing wheels and tires and am now trying to get the inner duals off. The stud has what appears to be a 1-1/8 by 16 threads and on the outer end of the stud it is square. I got the outers off but the inners seem to still be quite tight. Is there something more I need to do to loosen the inner wheel? thanks for your help!
Harrydale
With a 13/16" square socket remove the inner nuts.
Be aware that you probably have left-hand threads on the left side of the truck, and right on the right.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
put an appropriate size wrench on that square end and take off the studs [caps over the actual studs really], which are the 'lug nuts' for the inners
