1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#759900 07/05/2011 11:11 AM
After years of trying to fix the stock 216 in my 46 i have run out of patience. Is there a donor vehicle that i could swap engine and drive train out of to finally get my truck on the road???
Jimferrar #759902 07/05/2011 11:29 AM
I don't know what problems you have with the 216 but they are very similar to the engines that are popular replacements. Generally there is no need to replace the rest of the driveline if all you are concerned about is the motor. The tech
tips section has some great information on what years of motor to look for and how to swap them.
1951 1 Ton Completed
It really depends on what end result you want. If it's just to have a running engine most any 235 would do. I say 235 because there are a lot more of those out there than the 216. However if you want to upgrade your drive train so you can cruise above 45 mph then I would look for a 261, Canadian if you can find one. Those 261's had hydraulic lifters and full flow oil. However the American 261 may have had hydraulic lifters as well. Pontiac used a lot of the 261.
~Jim
