6 members (Bill Hanlon, Cletus1950, Rustnut, Bucker, 52Carl, frogfarmer), 81 guests, and 2 robots.
Topics128,178
Posts1,057,063
Members48,460
#759730 07/04/2011 8:17 PM
Z
ZMi
Offline
Z Offline
I have two questions about my 61 235
Is exhaust coming out of the crank case breather normal?
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=756240#Post756240
Thank you eveyone, happy 4th
Probably a sign of worn rings. Do a compression test on each cylinder, note the number, then squirt some oil in the cylinder and run the test again. If you get an increase in compression with oil in the cylinder, your ready for new rings.
Riding in the Passing Lane
A small amount is normal. It is not exhaust. It is blowby. It is compression that leaks by the piston rings. If it is excessive it is an indication you have worn out piston rings. If it is puffing you could have a burn't piston. If the oil is thined out from needing changing or poluted from gas it will also cause this. Sometimes a heavier viscosity oil will help.
1972 Chevy c10 Cheyenne Super
