8 members (mason86, Otto Skorzeny, Hotrod Lincoln, Ol'55, Oswald, klhansen, 32Fordpuchoptop, 1 invisible),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Anyone know of a good source for cheap zinc blocks? Hearing that the chassis wasn't originally painted, I'm learning that the whole thing may have been the sacrificial anode, but since I painted my chassis, all my exposed bolts, rotors, master cylinder, etc., are all rusting pretty fast. I'm hear on the salty air coast.. I guess I could try my local boat shop?
Dave
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sounds like you must have been a sailor at one time or another Dave. Could you explain how that would work or be used on an Advanced Design truck???
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 'California truck' getting rust? Next you'll tell me there is no Easter Bunnie. | | | | | Joined: Jun 2011 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 117 | | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks, that'll work. Denny, I just planned on bolting them onto several spots along the rail. Looking through your project I'm sure you're familiar with this, but for reference to those who aren't, galvanic corrosion . The zinc blocks are the sacrificial anode meaning they corrode away while your steel is protected. The other cathodic protection scheme I know of is impressed current which does what is says, pushing the current with a power source instead of through the natural voltage potential between dissimilar metals. That's more for industrial, stationary stuff though.
Dave
