6 members (greenie-reddy, GMCJammer51, 2-Ton, 3B, 55shaker, JW51), 94 guests, and 0 robots.
Topics128,154
Posts1,056,834
Members48,456
#759324 07/02/2011 10:30 PM
Q
QX
Offline
Q Offline
i have had this truck @ the farm for about a month. i have some time on my hands to read or research for info. i am not wrench man. the truck does turn over, i would like the truck to run as is. no key found yet.it appears to have no oil filter.
thanks for any help
QX #759457 07/03/2011 4:07 PM
Oil filters were a dealer option. Run a wire from the positive cable connection on your starter to the positive connection on your coil.Make sure the truck has fuel, You may have to pour a small amount of gas into the carburetor. This should let you know if it is going to run. My truck is a 49 5 window 216 3800 just like yours. Let me know how it goes. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Don't use the fuel in the gas tank. Old gas can seize valves.
