6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#7592 06/05/2003 4:36 PM
When I began working on a 63 Chevy, the speedometer didn't work ... which wasn't surprising, because the cable was disconnected. I've reconnected to the dash, but where the heck does the other end hook? I crawled around for an hour, then figured some of y'all would know. It's a regular 3-speed manual, modified from the tree to the floor, if that makes a difference.
I know the connector is there somewhere, I'm just missing it!
thanks!
When in danger, when in doubt, run in circles, scream and shout.
-- Tom Servo
Hi!
First of all: dont use my reply as your "bible", but I think the wire connects to the tranny..
Somebody correct me if Im wrong!!
Typically the other end conects to the tail end of the tranny.
Welcome to the SBP
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
...and on the left side.
Driver's side, near the tail end of the tranny. More than likely it's covered in 40 years of crud. There should also be a small bolt (3/8s?)on the tranny where the cable goes in. It holds it into the trans. (working from memory, don't curse at me if I'm wrong:))
Glad to see someone else with a '63 on here.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
Most of the cheap aftermarket three speed shifters I have seen usually make it hard to hook up the speedo cable without modifing the bracket that bolts the shifter to the trans. The part you screw the cable on is usually behind the shifter assembly,hopefully the person who installed it was too lazy to hook the cable back up but you might have to cut out the bracket some to get the cable hooked up or find one of those 90 degree angle adapters that some trucks have to get the cable to work.
Thanks, folks for the replies!
Jeff, I fear your's may be the most logical. It's definitely aftermarket, judging from the gaping hole cut in the floor. Truck belonged to my uncle and was given to me with the understanding I fix it. When I started poking around the wiring, I should've given it back!!
But heck it's family and I have a lot of good memories, tossing melons to the hogs in the back of the truck. It's never gonna be a show truck, but it would be nice to know how fast (or slow) it's going!
Thanks again!
-- Tom Servo
you don't need a speedo. But a good loocking girl in the back and watch what happens
10 miles hairs are moving slowly
20 miles hairs start to fly horizontal
30 miles her scirt moves up and exposes
here legs
40 miles here shirt gets unbuttoned
50 miles she is holding on to here bra
60 miles youre truck is flat out and you have no time to watch the girl
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
Fritz I was going to fix my speedometer, but i think I like your idea better
Junior Member
Junior Member
Hi
I'm new here and just starting to get into my '64 C10.
I too have an aftermarket floor shifter that prevents me from connecting the speedo cable.
Does anyone have a source for a 90-degree connector for the cable?
thanks!
Casey
1964 Chevy C10
1960 Thunderbird
