1 members (Rusty Heaps),
112
Mod | | | Forums66 Topics128,129 Posts1,056,695 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 33 New Guy | | New Guy Joined: May 2011 Posts: 33 | i have had this truck @ the farm for about a month. i have some time on my hands to read or research for info. i am not wrench man. the truck does turn over, i would like the truck to run as is. no key found yet.it appears to have no oil filter.
thanks for any help | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Oil filters were a dealer option. Run a wire from the positive cable connection on your starter to the positive connection on your coil.Make sure the truck has fuel, You may have to pour a small amount of gas into the carburetor. This should let you know if it is going to run. My truck is a 49 5 window 216 3800 just like yours. Let me know how it goes. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Don't use the fuel in the gas tank. Old gas can seize valves. | | |
