| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Hi everyone! Would somebody please take a look at my generator and tell me if it is mounted "correctly"? It looks OK to me, but there was a lockwasher leftover, and it's been years since I removed it. Also, I wonder what the three threaded holes in the block at the rear of the generator are for? Also, is the "lid" on the top of the generator for oiling? I just blew the dust off and bolted it on. I thought I would test it to see if it works before replacing brushes and what not. BraceBracketFront view of engineThermostatWaterpumpThe thermostat opened in hot water at about 160 degrees, so it works. The waterpump probably works since it turns. There is a bit of a "wobble" in it though, hopefully it doesn't leak. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Stove
Based on your pics, it looks good. Just make sure that all the pulleys line up so the belt wont come off.
The lid is for oiling. A few drops per the shop manual. Your starter also has one too....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Thank-you gentlemen!
I need to find another lock washer. And it looks like the brace is attached to the wrong side of the generator, it just seemed to fit better that way. Perhaps my generator is mounted just a bit too far forward, if that is possible. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It’s possible to get the lower bracket on backwards; the holes are offset from the centerline Use a straight edge to check if the pulleys are lined up, very important that they are. DG
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If your pump has a "wobble" or looseness in it, it will most likely leak. That will be obvious if it does.
That is a very clean looking assembly toy have there. | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Denny, reversing the bracket did the trick, now the pulleys are properly aligned.
Thanks Fred, the engine is looking good!
I cleaned every part on a wire wheel (except the fan which I sandblasted, and the manifold which I left alone). Everything then got a coat of "rust-stop", which I imagine is some kind of mixture of acid, oil, and stickum.
I briefly considered painting the parts, but this would've been a pain in the butt. Painting is time consuming, messy, and tricky to get right, and paint scratches.
I thought about doing nothing, just bolting the parts on rusty. But that wouldn't "feel right", and the engine would be ugly.
I think the bare metal with rust protection looks good, and it should stay looking good, and it was quick and easy. Once it starts running the engine will get covered with oil and grime, I suppose. But I can just roll into a car wash and clean it up, no problem.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I wonder what the three threaded holes in the block at the rear of the generator are for? On some car, not truck applications, those holes were used to attach motor mounts, with a third mount on the back of the transmission. Pickups and bigger trucks used mounts near the front crankshaft pulley and the bellhousing, with the transmission unsupported at the rear. On your truck, the holes have no purpose, since the engine has mounts front and rear. Jerry
