| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 7 New Guy | | New Guy Joined: Apr 2003 Posts: 7 | When I began working on a 63 Chevy, the speedometer didn't work ... which wasn't surprising, because the cable was disconnected. I've reconnected to the dash, but where the heck does the other end hook? I crawled around for an hour, then figured some of y'all would know. It's a regular 3-speed manual, modified from the tree to the floor, if that makes a difference.
I know the connector is there somewhere, I'm just missing it!
thanks!
When in danger, when in doubt, run in circles, scream and shout. -- Tom Servo
| | | | | Joined: Apr 2003 Posts: 12 Member | | Member Joined: Apr 2003 Posts: 12 | Hi!
First of all: dont use my reply as your "bible", but I think the wire connects to the tranny..
Somebody correct me if Im wrong!! | | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | Typically the other end conects to the tail end of the tranny.
Welcome to the SBP
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Driver's side, near the tail end of the tranny. More than likely it's covered in 40 years of crud. There should also be a small bolt (3/8s?)on the tranny where the cable goes in. It holds it into the trans. (working from memory, don't curse at me if I'm wrong:)) Glad to see someone else with a '63 on here.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Most of the cheap aftermarket three speed shifters I have seen usually make it hard to hook up the speedo cable without modifing the bracket that bolts the shifter to the trans. The part you screw the cable on is usually behind the shifter assembly,hopefully the person who installed it was too lazy to hook the cable back up but you might have to cut out the bracket some to get the cable hooked up or find one of those 90 degree angle adapters that some trucks have to get the cable to work. | | | | | Joined: Apr 2003 Posts: 7 New Guy | | New Guy Joined: Apr 2003 Posts: 7 | Thanks, folks for the replies!
Jeff, I fear your's may be the most logical. It's definitely aftermarket, judging from the gaping hole cut in the floor. Truck belonged to my uncle and was given to me with the understanding I fix it. When I started poking around the wiring, I should've given it back!!
But heck it's family and I have a lot of good memories, tossing melons to the hogs in the back of the truck. It's never gonna be a show truck, but it would be nice to know how fast (or slow) it's going!
Thanks again!
| | | | | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | you don't need a speedo. But a good loocking girl in the back and watch what happens
10 miles hairs are moving slowly 20 miles hairs start to fly horizontal 30 miles her scirt moves up and exposes here legs 40 miles here shirt gets unbuttoned 50 miles she is holding on to here bra 60 miles youre truck is flat out and you have no time to watch the girl | | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Fritz I was going to fix my speedometer, but i think I like your idea better | | | | | Joined: Apr 2006 Posts: 1 Junior Member | | Junior Member Joined: Apr 2006 Posts: 1 | Hi I'm new here and just starting to get into my '64 C10. I too have an aftermarket floor shifter that prevents me from connecting the speedo cable. Does anyone have a source for a 90-degree connector for the cable?
thanks!
Casey 1964 Chevy C10 1960 Thunderbird
