2 members (dt235sd, Bucker),
146
0
Mod | | | Forums66 Topics128,196 Posts1,057,390 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 17 New Guy | | New Guy Joined: Jul 2010 Posts: 17 | Hi, im hoping someone out there can help me out, i purchased a 39 chevy 1/2 ton but it did not have the original rear fenders. i have purchased 2 rear fenders but i was told they are not correct for 39. i know that 39 fenders are wider than 40-46 fenders...does any one have measurments for a true 39 rear fender??? it would help me out alot so i can tell for sure when and if i run into one...i would need the length of the fender, the width of the fender from the the top inside edge to the outside edge and the width of the wheel opening..thanks!!!! | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | If you don't get a response here, check the shop area, Making a Stovebolt Bed section. The folks at Mar-K probably have all the dimensions handy. And, let's see some pics!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jul 2010 Posts: 17 New Guy | | New Guy Joined: Jul 2010 Posts: 17 | | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | A '39 PU rear fender looks just like a '40-'46 PU rear fender from a side view, except for being 1-3/8" wider. If you lay the fenders on the floor, or measure from the box side to the wheel opening, the '39 fenders will be about 13" wide, and the '40-'46 about 11-1/2" wide. This is measured at the top of the wheel opening. | | | | | Joined: Jul 2010 Posts: 17 New Guy | | New Guy Joined: Jul 2010 Posts: 17 | @Barry weeks So are 40-46 rear fenders the same length, and height as 39???... So as long as I have a 13" wide fender I can consider it original?? Thanks for your information !!!! | | |
