| | | Forums66 Topics128,089 Posts1,056,436 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 28 New Guy | | New Guy Joined: Dec 2008 Posts: 28 | I'm working on a 1952 GMC on a S10 frame with a sbc. I'm having trouble deciding what 12v battery to use and where to mount it? The original floor hole is blocked by the frame. The firewall area has air and heat lines there. If I put it in the truck bed it just kind of sets there in the open. I've read about the dry cell type batteries that could set under the front seat. HELP!!!!!!!!!!!!!!!!! Thanks | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | The " Optima " line of batteries can be mounted in just about any orientation you need. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Several rod companies offer really slick battery boxes that drop down for access here is and example of one. http://www.speedwaymotors.com/Drop-out-Battery-Box,5047.html They also carry other styles and have great customer service. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I bought mine at CPP Classic Performance Products CPP for $109.00 This looks to be the same product that speedway is offering. Mine is stainless (you can get black) group 24. The Group 26 is a bit larger and a bit more $. MY BOX
~Jim
