5 members (NH46COE, Hotrod Lincoln, Hanks custodian, Otto Skorzeny, 1 invisible), 126 guests, and 7 robots.
Topics128,077
Posts1,056,031
Members48,433
#754166 06/13/2011 3:22 AM
I bought headliner for this truck Installed the front and back headliner. My question is how does the center get put together blind clips or what?
Bennie
You should have a center rib support that the center retainer mounts to. The headliner slides in at the center and is retained front and rear with trim strips. I have mine at the chrome shop now but have seen some stainless.
I thought that is how the center is put together but I don't have the center strip. I have looked in all of the parts places and have not found one. Do you know where I could get one?
Bennie
You might have to check e-bay, I'll check my stuff and see if I have a spare out there.
Thanks let me know if you have one and I will check on e-bay
I have half of what you need. I have the base bow but not the trim piece that screws to the base bow. the base bow attaches with two screws above each door opening.
I really don't understand the terms let me understand what I need comes in 3 pieces? You have the bow that goes across the top of the cab? I will still need the pieces that attaches the bow to the top of the doors?
Bennie
There is just two pieces, There's the piece that mounts closest to the roof and the other piece mounts to it. The piece I have mounts closest to the roof it requires two mounting screws for each side. The piece I do not have mounts to the piece I have I think with about 6 screws which divides the headliner. If you look midways between the upper door sill you should see two screw holes on each side. I guess I could take a picture of the piece I have. Hope this helps. G
There are 1 piece either ABS or Fiberglass available from Chevs of the 40's, the Filling Station or Jim carters. I have seen the pieces on ebay for the two piece.
Does anybody put (or have recommendations) for insulation between the headliner and metal roof?
Dennis
oldbluetruck, I have insulated the roof of my 46. I first put a layer of peel-n-seal on the metal roof to cut down on the noise, then I got a water heater blanket, you know the ones that are foil on one side and ground up carpet on the other. I used 3m spray adhesive to glue it up to the roof. Shinney side towards the interior of the cab.
It's been that way for about 8 years now and works fine.
George
Thanks George. I didn't think of the water heater blanket. Nice idea.
Unfortuneately, I looked up the peel-n-seal and it was not available in any Lowes near me. I wonder why?
Dennis
Here's the outer or exposed bow of center trim on ebay that you need. Now all you need is the piece this mounts to.
http://cgi.ebay.com/ebaymotors/1939...arts_Accessories&hash=item5199fe4b03
Moderated by  ndkid275, Phak1
